Trunk Board - NCRS Discussion Boards
Trunk Board
  • Jack A.
    • March 1, 2001
    • 129
    Trunk Board
    I am restoring my 61 and would like to recreate as close as possible the original Trunk Board/Spare tire cover. I have read the Judging Manual for my car.I have an original Board for a template. I have found the correct Plywood to make it out of and have already cut it out. What I need is the "Black Stain" that it refers to and the Glue that was used to glue down the labels. Any thoughts or tips you have on this would be appreciated.
    Regards
    Jack Aexander 35730
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: Trunk Board
    Jack,
    For the black stain get any oil based wood stain, Jacobean is a good black color.
    Do a sample application. Wipe it on and then wipe it off quickly.
    If it looks to dark dilute the stain with thinner, possibly mineral spirits.
    Try it again.
    The finished board should have light and dark areas where the stain gets absorbed by the grain.
    I'm not sure about the glue.
    • David B.
      • July 31, 2004
      • 330
      Re: Trunk Board
      "I have found the correct Plywood to make it out of and have already cut it out."
      Jack,
      Can you tell me about the plywood you selected? And, where to get it?
      Dave
      Dave, 1969 427, 1957
      Previous: 1968 427, 1973 454
      • Bill M.
        • April 1, 1977
        • 1386
        Re: Trunk Board
        Here's a picture of the grain on the original board for my '59
        • Jack A.
          • March 1, 2001
          • 129
          Re: Trunk Board
          The plywood I selected was what the Judging Manual describes as 3/8" thick 5 ply construction grade but withourt the plugs used comonly today to fill knot holes. A 5 ply 3/8" plywood is not found in most lumber supply places. What I did was go to a specalty plywood wholesaler. I specified what I was looking for and he had it. I had to purchase a full 4' X 8" sheet for about $27.00. The only differences are these. On the original. The botton side of the example I have shows unfilled knot holes. It is a nominal 3/8 " thick which is used in modern plywoods. This means it is about 1/16" shy of 3/8 ". I have yet to stain it so I'm not sure how close the grain will be.
          You can contact your local lumber or cabinet shop to locate a plywood supplier near you, or use the internet.
          I hope this helps
          • J O.
            • August 31, 1987
            • 19
            Re: Trunk Board
            jack.
            here you go...
            bill mashinters trunk board looks perfect...
            try using English Chestnut #233 stain and put 2 maybe 3 coats on you're board. (using a rag)
            hope this helps.
            john
            • Jack A.
              • March 1, 2001
              • 129
              Re: Trunk Board
              Thanks John. I will try that. I also picked up a minwax stain called "Ebony" I thought I would experiment with.
              Jack
              • Joe E.
                • April 1, 1985
                • 77
                Re: Trunk Board
                Jack
                Here is a picture of a original 62 trunk board.
                • Ray C.
                  • June 30, 2001
                  • 1132
                  Re: Trunk Board
                  Joe, Do you know the exact thickness of the fir plywood?
                  Ray
                  Ray Carney
                  1961 Sateen Silver 270-HP
                  1961 Fawn Beige 315-HP
                  • Joe E.
                    • April 1, 1985
                    • 77
                    Re: Trunk Board
                    The thickness of the trunk board is .370" and 5 layers.
                    • Joel M.
                      • May 31, 1975
                      • 141
                      Re: Trunk Board
                      Is there a known source on Carolina Yellow Pine 5 ply (5 x .075) plywood with an A grade face. B or C grade may be ok for backside. Or a source on A grade .075 veneer in Carolina Yellow Pine?
                      • Donald H.
                        • November 2, 2009
                        • 2586
                        Re: Trunk Board
                        I need to make one also for my 1960. The TIM has same specs, e.g. 3/8" plywood, 5 plys. Can someone give the correct diameter for the board? I do not have one to reference.
                        Don Harris
                        Don Harris
                        Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
                        • Bill M.
                          • April 1, 1977
                          • 1386
                          Re: Trunk Board
                          Don Harris
                          My '59 is 30-3/8 +/- 1/16
                          • Dan D.
                            • November 5, 2008
                            • 1323
                            Re: Trunk Board
                            You certainly can experiment with Minwax, but Minwax is about 50% stain and 50% dye. That makes it as thin as water and it soaks up like crazy on soft woods. Pretreating with wood conditioner will help, but I don't think that pure Minwax over raw plywood will yield satisfactory results. McCloskey or Cabot may be a better choice. -Dan-
                            • Joe E.
                              • April 1, 1985
                              • 77
                              Re: Trunk Board
                              The 62 trunk board is 30-3/8".
