I want to thank everyone on the board for helping me. I have a '67 coupe with a 327/350 that I just had rebuilt. A "professional" rebuilt the engine to the tune of $5500. Since I was building the car to drive, he put in 9/1 pistons and a Comp Cams 262H camshaft. He ran it on his dyno, and it made 336 HP, which I was very satisfied with. However, after the engine was back in the car, it wouldn't run for ****. Turns out that I couldn't get it timed right. Nothing I tried worked; I couldn't even get the thing to run with the timing set to spec. First problem; even though it was a "pro build", he hadn't rebuilt (or even checked) the harmonic balance. It was the old original, and the timing marks had slipped. I figured, "OK, I can get it close with a vacuum gauge" so tried to set it up that way. I couldn't get more than 12 inches of vacuum or get it to run decent for anything. I went through the TDB, and came across the posts about the "dimple" on the distributor drive gear. I pulled my distributor, and sure enough, it was 180 degrees off. I punched out the pin, turned the gear 180, and now everything is fine. I'm sure he ran the engine on the dyno without the shield/coil mounting bracket, and was able to twist the distributor enough to get the readings he got. (I should have known, because when I got the engine back, the plug wires were off one hole on the distributor.) Oh, by the way, this was after I had spent $475 on the local garage that has a very good reputation and all of the "proper" skills and equipment.
This was a problem that seems to be very specific to C2's, but nobody outside of here seems to know about it.
I do have one question; This whole thing has been a real time consuming mess for me. I'm up here in Minnesota, and would really like to enjoy this car the rest of the summer. Am I taking a chance on running the rest of the summer with the current harmonic balancer? I'd hate to have it come apart and tear up my car, but I'd really like to enjoy the rest of the summer and send the balancer out to be rebuilt this fall. Outside of the slipped timing marks, it seems fine.
Again, thanks for information that seems to be available nowhere else.
(BTW, our unleaded premium with no alcohol is 91 octane.)
