1967 Power Steering Belt - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5186
    Can someone tell me the correct length for the power steering belt on my 67 327/300hp no A/C. I have a old GM belt # 9433725 that's 36.5" but I can't find the listing in my old parts book. I would think the 1963-5 35" belt would be correct because the pulleys are the same.
    Crankshaft pulley is #232 and P/S pump pulley is #509. Is this crankshaft add on pulley still available from GM and how much should I expect to pay for a new pulley, mine has a wobble. Love the P/S on the car..
    Thanks for the help...
  • Mark G.
    • March 1, 2001
    • 227
    Re: 1967 Power Steering Belt
    Timothy -
    The '66 AMA specifications call for a 36.25" P/S belt. The pulley configurations are the same for both years. The alternator belt is 53.25" long. Of course the "V" angle is 38-42 degrees and it is .38" wide.
    Mark
    • Timothy B.
      • April 30, 1983
      • 5186
      Thanks Mark,
      I am curious about the length because I think the 63-65 belt is 35" and the pulleys are the same for the low hp cars... If that's true why the 36+ " belt for 66-7.
      • Dick W.
        • 10483
        The reason you cannot find the part number in the older parts books is that the General, over the years, changed all belt numbers to a 9******* number.
        Dick Whittington
        • Timothy B.
          • April 30, 1983
          • 5186
          Thanks Dick,
          That still does not explain why the 63-65 35" belt is not called out for the 1966-67 same pulley set up.
          • Mark G.
            • March 1, 2001
            • 227
            Mark
            • Timothy B.
              • April 30, 1983
              • 5186
              Mark,
              The L-79 has a different pulley arrangement using a cast iron P/S pump pulley that lines with the #533 double groove crank pulley. The diameter of these pulleys is probably different so the belt may be different.
              Low hp used the same pulley arrangement as 63-5 but the belt call out is different.
              • Mark G.
                • March 1, 2001
                • 227
                Timothy -
                Yes I charted the '65 - '67 pulley configurations and have the drawings. The P/S pumps changed during the model years. This may have also required different mounting brackets too. I have not looked into those revisions. The '66 AMA just lists specifications; the '67 probably does the same. It does not indicate if it fits or works under restored and service replacement conditions. Just a reference point.
                Mark
                • Timothy B.
                  • April 30, 1983
                  • 5186
                  Mark,
                  Good point about the P/S pump brackets as I know they changed by 67 to the style with the tubes where the two bolts hold the pump to the block.
                  I also know the 63 P/S adjustment bracket that bolts to the motor mount is shaped a bit different than the later bracket but I am not sure how any of this affects the belt. The resto package for my 67 says 36.25" for low hp /W power steering.
