66 AO Smith - NCRS Discussion Boards
66 AO Smith
  • Karl K.
    • November 17, 2008
    • 92
    66 AO Smith
    Hello Everyone,
    I looked at a 66 427 convertable today and it had an
    AO smith body, I thought all big blocks had bodies from
    St Louis?
    Karl
  • Douglas L.
    • August 31, 2003
    • 302
    Re: 66 AO Smith
    Karl,
    I believe that is true only for 67 because of the difficulty of getting the 67 big block hoods painted correctly.
    • Larry M.
      • January 1, 1992
      • 2703
      Re: 66 AO Smith
      Originally posted by Douglas Lee (40617)
      Karl,
      Correct. 1965 and 1966 big blocks could be either AOS or STL bodies. MAYBE even a few of the first 1967's.
      Larry
      • Mark G.
        • March 1, 2001
        • 227
        Re: 66 AO Smith
        Karl -
        Good information; be careful with AOS cars ('65-67) that include RPO N14.
        Mark
        • Karl K.
          • November 17, 2008
          • 92
          Re: 66 AO Smith
          This car had side exhaust at one time, was switched to
          under car exhaust for judging now has the side exhaust
          back on it. Is there a way to tell how it started out?
          Why couldn't they get the hoods painted correctly?
          Thanks.
          • Larry M.
            • January 1, 1992
            • 2703
            Re: 66 AO Smith
            Thanks.
            Karl:
            If it is an AOS body, it started life as an UNDERCAR exhaust. AOS built bodies did not originally have sidepipes. Additional info and reasons etc. are in the archives.
            Larry
              Re: 66 AO Smith
              Thanks.
              Karl -
              The in-line paint repair prep booth in the A.O. Smith paint shop in Ionia prior to the final bake oven wasn't long enough to accommodate the labor-intensive and time-consuming big-block hood masking operation, which involved three separate stencils plus hand-taping. After the initial 1967 launch, all big-block orders were allocated to St. Louis, which had adequate space for the operation.
              • John M.
                • April 30, 2004
                • 111
                Re: 66 AO Smith
                Karl, Just curious, but where did you look at this 1966 AO Smith Car??
                • Karl K.
                  • November 17, 2008
                  • 92
                  Re: 66 AO Smith
                  Hi John,
                  I really don't remember, we had looked at alot of cars
                  before getting one.
                  Karl
