65 Front Caliper bolts - NCRS Discussion Boards
  • Gary C.
    • April 1, 1998
    • 380
    Which front caliper bolts are correct for a 65?
    I have 3 of the ones on the right which I think are correct and 1 of the one on the left.
    Gary
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 65 Front Caliper bolts
    I have 3 of the ones on the right which I think are correct and 1 of the one on the left. ....
    Gary -- your guess is correct; the ones on the right. Yours are the same as the caliper half bolts on my late '65 originals. Also, same style head on rear caliper-half bolts, except smaller.
    • Gary C.
      • April 1, 1998
      • 380
      Thanks Wayne.
      Where do you think I may be able to get 1 front bolt and 4 for the rear calipers from?
      • Joe R.
        • July 31, 1976
        • 4552
        Call SSB or Lonestar. They should have hundreds of them.
        JR
        • Gary C.
          • April 1, 1998
          • 380
          Thanks Joe,
          I have emailed them.
          Gary
          Perth Australia
            • 43290
            Thanks Wayne.
            Gary-----
            These are called place bolts. They are still manufactured and available, although they have not been available from GM for many years.
              Place bolts are unique self-locking fasteners - they have a circular undercut on the bottom of the bolt head; that undercut, together with the grooves across the top of the hex sections, causes the head to distort slightly at full torque, which maintains clamping force in the joint.
              AMK Products has them, and Fastenal probably does too.
              • Gary C.
                • April 1, 1998
                • 380
                Thanks very much for your input gents.
                I have ordered a set from Lonestar.
                • Grant W.
                  • December 1, 1987
                  • 407
                  HI Gary
                  How many did you order and what did it cost. Did the ones you order have those little letters on the ends, Just wondering.
                  Thanks, grant
                  • Gary C.
                    • April 1, 1998
                    • 380
                    G'Day Grant,
                    They are $2.50 each from Lonestar. I did not ask about the letters and I ordered 1 front and 4 rears.
                    Cheers,
                    Gary
