1967 electrical fuses - NCRS Discussion Boards
  • John D.
    • December 1, 1979
    • 5507
    Re: 1967 electrical fuses
    Originally posted by Timothy Barbieri (6542)
    Pete,
    Thanks for the information.. Can you tell me what issue restorer the article is written. I purchased these color coded fuses for my 63 years ago from LI only to discover they were not used in 63.
    DITTO. Whew Tim. Guess we both weren't up to snuff years ago. One thing good though is I keep them in the tool box for spares just in case something goes out in the LWC. JD
    • Brian M.
      • February 1, 1997
      • 1840
      Didn't Littlefuse stripe them on the outside?
      Originally posted by Peter Lindahl (6598)
      Tim - I checked the LI Catalog I have, #22, and they are listed as FUSE SET (OEM WITH CORRECT COLOR STRIPES)(8 PC) for 63-67. While I find LI is usually correct on their applications, the first application of the color-coded fuses to Corvettes and other other GM vehicles was with the 1967 production year. Also, worth noting for my experience is that while the color stripes are were "correct" on the sets I have seen the stripe is on the outside of the glass tube while the original Buss color-coded glass tube fuses had the stripe on the inside of the glass tube. Pete
      • Peter L.
        • May 31, 1983
        • 1930
        #18
        Brian - All the examples of Littelfuse glass tube fuses that I've seen that were color coded had a "dot" or dab of the coding paint on the outside of the glass which is one of the accepted methods of color-coding. I have not seen any examples of Littelfuse fuses with a colored stripe around the glass tube, but that's not to say Littelfuse didn't use that method also; it's that I haven't seen examples of them. If you have examples, I'd be interested in seeing some. Pete
        • Brian M.
          • February 1, 1997
          • 1840
          #19
          Pete, I have no examples of colored little fuses but it has come up in conversations.
          • Peter L.
            • May 31, 1983
            • 1930
            #20
            Brian - Thanks. If the topic comes up again, "kick my tire." I'm always looking to learn new old things. Pete
            • Robert G.
              • May 31, 1990
              • 429
              #21
              Here is an example of a Littelfuse with the stripe and amperage painted on the outside for a 15amp fuse.
                Robert -
                Littelfuse obviously had a Manufacturing guy making the decision to paint-mark the fuses on the outside rather than on the inside; that eliminated the need to stage the glass tubes for AGC fuses ahead of cap-and-element assembly by colors for the various amp ratings; they could mark them after assembly, using one common glass tube for all ratings.
