1954 6 cylinder question - NCRS Discussion Boards
  • Joseph T.
    • April 30, 1976
    • 2074
    Does anyone have a chevy passenger car six cylinder in their 54 Corvette?
    If so..what did you use for a powerglide, water pump, transmission lines etc?
    Joe
  • Roy B.
    • January 31, 1975
    • 7044
    Re: 1954 6 cylinder question
    Joe
    If they did they use a car engine, keep the original PG, install a repro corvette 54 water pump and the PG if car can be modi. To a Corvette PG , also Corvette PG dint use lines so block off the inlet & outlet lines if car PG is used
    • Joseph T.
      • April 30, 1976
      • 2074
      Roy
      Which is the best option?
      * add real 54 corvette powerglide to NOM chevy 6 engine
      or
      * just use the entire NOM chevy engine and chevy powerglide and just remove the transmission lines and block the inlet and outlet holes
      Trying to work with what I have in the garage.
      I have the corvette 6 cylinder engine mounts right and left. What do I need for brackets on the engine. Not looking to make a top flight engine..just one that works.
      • Joseph T.
        • April 30, 1976
        • 2074
        Who is making the repo 54 corvette water pump?
        • Roy B.
          • January 31, 1975
          • 7044
          You see them on e-bay all the time
          • Roy B.
            • January 31, 1975
            • 7044
            Roy
            or
            * just use the entire NOM chevy engine and chevy powerglide and just remove the transmission lines and block the inlet and outlet holes=YES 55 or 56 car
            If you don't have the original PG they cost big bucks, find a 6 engine car like a 55 ,56 Chevy with the PG because it will have a open drive shaft outlet and then you have a drive shaft made to fit that.Yes block off the PG lines ! Engine mounts can also be found on e-bay that you need .
