understanding AIM - NCRS Discussion Boards
understanding AIM
  • Bill H.
    • November 15, 2007
    • 54
    understanding AIM
    Is the AIM set up in the same way the car went down the assembly line?
    I am assembling the interior of a 66 bb from scratch. (nothing in the car)
    do I run the wiring harness before the sound insulation or after. Does brake/clutch assembly go in b4 isulation.
    how should I go about wiring harness and dash/ guages assembly?
    I put in the heater box and figured out you cant get at the vents then, so I hope there is a method to the madness that i could follow.
    I am trying to follow the AIM but as a rookie I get easily distracted.
  • Tom H.
    • December 1, 1993
    • 3440
    Re: understanding AIM
    Good question. I have never mastered the AIM either. Takes me forever to find anything in it.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Pat M.
      • April 1, 2006
      • 1582
      I've never mastered it either. If you ask me, I think there's madness to the method!
        Bill -
        No, it's not. The AIM sequence matches the sequence of the Engineering Releasing system; it was furnished by Engineering Graphics as an aid to the assembly plant, but it's not a process document. The actual assembly process sequence was developed and documented internally by the (Manufacturing) Production Engineering Group and the plant Industrial Engineering Department, and none of those documents have ever been found or published - they went in the dumpster when the lights went out in 1981.
          Tom -
          Here's the "magic decoder ring" for the AIM; there's a Contents Sheet at the beginning of each UPC Group that shows what's on each sheet in that section so you can find what you're looking for. The UPC section covers every single part required to build a "base car" with no options - only standard equipment.
          UPC 0 - General Information
          UPC 1 - Body Construction and Trim
          UPC 2 - Frame
          UPC 3 - Front Suspension
          UPC 4 - Driveshaft and Rear Suspension
          UPC 5 - Brakes
          UPC 6 - Engine
          UPC 7 - Transmission & Clutch
          UPC 8 - Fuel & Exhaust
          UPC 9 - Steering
          UPC 10 - Wheels & Tires
          UPC 11/13 - Grille, Front End, and Cooling
          UPC 12 - Electrical
          UPC 14 - Bumpers & Miscellaneous
          The second section covers all the options, organized in alphabetical order by RPO number (A31 first, Z06 last, etc.), and each option section also has a Contents sheet so you can find the sheet that has what you're looking for.
          Every part that was installed at St. Louis is called out with a part number; you won't find part numbers for things like wheel bearings, as they were detail parts of assemblies as received at St. Louis.
          It's second nature when you've worked with it since 1964 like I have, but if you haven't, just follow the directions above.
          • Paul J.
            • September 9, 2008
            • 2091
            Bill;
            Don't make this too complicated. Only a few parts have a set assembly sequence. John and others can tell you that manufacturing assembly considerations (for everything including toasters) try to maximize efficiencies and minimize costs. It does'nt mean that some guy in his garage can't follow a different sequence and end up with same result.
            Since you said that you were a rookie, ideally you should find another 66 to compare to, but if not, a few carefully asked questions to this board can probably get you through the process.
            I find automotive assembly a lot like building a house. There's a logical sequence that must occur in some areas, like the footings must go in before the foundation. But the mechanicals like plumbing, electrical, and HVAC have no set order other than to follow the rough frame in.
            Paul
            • Tom H.
              • December 1, 1993
              • 3440
              Tom -
              UPC 2 - Frame
              UPC 5 - Brakes
              UPC 6 - Engine
              UPC 9 - Steering
              UPC 12 - Electrical
              Thanks !!! That does make sense. What does UPC stand for ?? Now maybe you can help me get better at reading my parts books !!!
              I need a Corvette tutor !!
              Tom Hendricks
              • Rich P.
                • January 12, 2009
                • 1361
                If you notice Service manuals and Chassie Overhaul Manuals follow the same UPC order but just in Chapters.
                • Alan D.
                  • January 1, 2005
                  • 2053
                  Bill - "go about wiring harness and dash/ guages assembly?"
                  Assemble the entire dash, add wire harness, and then install. Was amazed how simple it was. In the past had left wiring harness in place and removed panel. A few simple tricks to make life better however ask when you get to that point. Would be nice to see one all together. PS add fuse for lighter!
                    • 15632
                    UPC = Universal Product Code -- I think. I wish John Hinckley had answered this one, but maybe he will confirm or correct me.
                    • Tom H.
                      • December 1, 1993
                      • 3440
                      Actually, now that I know how to read my manual, I have discovered UPC is UNIFORM PARTS CLASSIFICATION. Thanks to John for the lesson.
                      Tom Hendricks
