Inside a WCFB: Is this the result of Ethanol? - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    Today I opened up a WCFB from the 283 on the 59(nom '57 548). Used weekly to cruise nights and occasional trips. A brown powdery substance
    all over the bottom of the bowls. The accelerator pump plunger is disintegrated. What's left appears to be the leather type.
    Ethanol?
    Rich
  • Alexander C.
    • June 20, 2010
    • 353
    Re: Inside a WCFB: Is this the result of Ethanol?
    Wow, first thing I would normally think is contaminated fuel tank like rust but that's just crazy looking at that plunger
    May I ask how many miles and in how many years since they have been opened last?
    What ethanol mix is there where you live? 10%?
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11323
      Probably 1 or 2 thousand miles, maybe about 5-7 years. Ethanol everywhere about a year and a half ago, yes 10% or less at the pumps.
      I am planning to remove the tank and inspect and flush, or replace if needed. Won't get in there for a while though.
      Rich
      • Alexander C.
        • June 20, 2010
        • 353
        With that little fuel actually going through them over that amount of time with such low miles, are you using any kind of fuel stabilizer?
        No doubt that ethanol can have that affect on certain petrol based plastics, aging fuel can also contribute quite a bit. I've seen 87 octane go bad enough an engine wouldn't run on it's own in just 6 months. Dark mustard like hardened goop not more than a few months after that.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11323
          Car is in Florida and used year round on a weekly basis. There was a paper element filter in place of the typical screen type filter, so I'm wondering if the red particles are from the fuel in the bowls breaking down or the sediment in the fuel system before the carburetor got through it somehow.
          edit: or maybe the powdery substance is the paper filter itself breaking down?
          Rich
          • Ronald L.
            • October 18, 2009
            • 3248
            Really looks like rust - did you put a magnet to it? Does any of this pick up?
            Open the gas cap, is the tank clean and shiy inside, rusted, or???
            • Ken A.
              • July 31, 1986
              • 929
              Typical of WATER damage.
              • Clem Z.
                • January 1, 2006
                • 9427
                Rich
                that is a Q jet filter that was jammed into the carb and i doubt if it even filtered the gas as i bet most bypassed the filter because of the fit. was octane booster ever used because it will cause problems as they are mostly pure alcohol.
                • Ronald L.
                  • October 18, 2009
                  • 3248
                  Alcohol attracts and pulls the water vapor - mositure in the air into the mix...
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11323
                    It's not attracted to a magnet so it's not rust. The inside of the tank has some sediment. I forgot about the other filter between the pump and carburetor. It has the same reddish powdery substance on the outside of the filter. It's caked up as there was still some fuel in the filter before I cut it in half. I don't know if octane boost was used in this, but I doubt it.
                    I'm beginning to think what was in the carburetor was this bigger paper filter breaking down, combining with the little filter in the carb inlet(which likely wasn't sealed very well) and many years going by.
                    Maybe exacerbated by the ethanol fuel over the last year or so.
                    Rich
                    • Clem Z.
                      • January 1, 2006
                      • 9427
                      Rich
                      a lot of junk can come from the station tanks were you buy the fuel.
                      • Bob H.
                        • July 31, 2000
                        • 804
                        I had a similar problem on an all original 61. I could replace the filter and in a very short time, the filter was clogged again.
                        When we opened the tank it looked fine but what we finally discovered was that when I put fuel in it, the rubber neck was disintegrating from the inside. Maybe ethanol ralated?
                        The substance was extremely fine and we could not tell it was rubber by looking at it. Anyway, if you open it up, I suggest changing the rubber filler neck at the same time.
                        • Roy B.
                          • February 1, 1975
                          • 7044
                          You hit the nail on the head
                            • April 30, 1984
                            • 158
                            I have had the same issue here in Ohio as my friend has had in Fl. We both have had this VERY fine powder left in the carb bowl after the gas has evaporated . In my case the stuff gets past the filters because it is in the mixture of the fuel. The car did not start and I could not see fuel pumping so I thought fuel pump was bad. Bought new pump and took appart old pump and it was FILLED with the stuff. Prior to this mess, I had cleaned gas tank and replaced steel lines. All the rubber lines were also new.-John
                            • Richard M.
                              Super Moderator
                              • August 31, 1988
                              • 11323
                              Interesting......Ok, fuel pump coming apart next. Results to follow.
                              Rich
