Question for anyone who trailers their car. - NCRS Discussion Boards
  • Doug F.
    • June 30, 2005
    • 136
    My enclosed car trailer has built in d-rings with a dove tail too. However the rear d-rings are way to far back when I haul a C4. So, Im thinking of using an E-track perhaps. Thats my questions, has anyone every used the e-track set up and would this be the best way to go? What about installation? Thanks dwf
  • Jim L.
    • September 30, 1979
    • 1817
    Re: Question for anyone who trailers their car.
    I've seen a lot of E-track in car haulers so there is no doubt that it works.
    However, an awful lot of it seems to be held down with either lag bolts or sheet metal screws anchored into nothing more than floor wood. That just seems so very wrong.
    So, I'll stick with my D-rings which are bolted to brackets welded to the trailer frame.
    In your situation if need be, you could buy longer tie down straps.
    Jim
    • John F.
      • March 23, 2008
      • 2424
      I would not go back to using my D rings. The floor track is the best, but my trailer floor is all aluminum.
      John F
      • Gene M.
        • April 1, 1985
        • 4233
        Doug,
        My trailer also has the "D" rings far back. I have a two foot length of chain with the screw down links to allow using my standard length straps on both rears. Remember to mantain the X cross to keep the car in the center.
        • Mike G.
          • July 31, 2002
          • 709
          i have a 20' pace car hauler. i also have a c4 i tow in it. i use the rings in the floor to tie mine down. to keep the ballance right the car goes almost all the way to the back. about 5" from the back door. I pull the car in and hook up the front first with the car about 5 " back to far, even with the door. i then hook up the back straps to the rear suspension. i take the car out of gear and use the front straps to pull the car forward until its tight. put the car back in gear and close the door. i put a tape line on the wall that shows me where to stop depending on which car i am in. works well with a balanced, level trailer.
          • Jim L.
            • 1817
            You are on to something here, Mike. I do something similar with my vintage racer, which is slightly nose heavy.
            I center the wheelbase of the car over the midpoint between the two trailer axles. Since the front of the car is slightly heavier than the rear, this does nothing to lessen the tongue weight.
            The byproduct is two fold:
            1. My car is very near the trailer door which leaves a lot of storage room in front.
            2. The trailer tows easily and without porpoising.
            Jim
            • Doug F.
              • June 30, 2005
              • 136
              thanks all for the help....dwf
              • Phillip E.
                • November 15, 2006
                • 25
                . i put a tape line on the wall that shows me where to stop.
                I put a small piece of carpet on the wall to protect the edge of door when I open it.
                • Michael F.
                  • 745
                  why not back car in to put car rear closer to front of trailer to level out???????
                  Michael
                  70 Mulsanne Blue LT-1
                  03 Electron Blue Z06
