Third Break lights on 1992 coupe - NCRS Discussion Boards
  • Phil T.
    Infrequent User
    • July 31, 1997
    • 1
    Third break light is not working. Have checked the fuses, replaced the socket and bulb - any Ideas on what is going on?
  • Donald O.
    • May 31, 1990
    • 1593
    Re: Third Break lights on 1992 coupe
    Have you verified that you have 12vdc going to the HMSL when the brakes are applied? If not, I'd start there and trace back to where the wire originates, assuming the regular brake lights work.
    Don
    • Pete B.
      • February 22, 2007
      • 325
      Check out the brake light switch, my 89 had the same problem. The 3rd light power source is a "second" switch inside the regular switch.
      I spent 10 hours tracing leads looking for something wrong and in frustration opened up service manual saw the diagnostic on that light failure. Bought the $9 switch and all is well. So much time spent on such a simple fix!
      Pete Bergmann
      2005 - 2013 C6 National Teamleader
