C2 Rear suspension - NCRS Discussion Boards
C2 Rear suspension
  • Doug L.
    • March 14, 2010
    • 442
    C2 Rear suspension
    Hi Guys,
    I have searched the archives but have not found an answer to my 2 (immeidate) problems.
    I have disassembled and removed most components of the rear end/suspension of my '64. I will need to install new bushings in the trailing arms (at their forward pivot points). My manual describes flairing the bushing with a special tool which I obviously don't have. Has anyone found a solution to the lack of this tool, or is there someone that has the tooling to do this for a fee?
    After dropping the differential and rear spring I tried to remove the rear suspension crossmember. The manual seems to indicate that it is just a matter of removing the 2 bolts that pass through the center of the rubber cushions. I removed them and the cross member stayed in place. I tried gently prying with a crowbar. Nothing moved. Do I need to just get bad with it or is there something missing from the shop manual?
    Thanks in advance for any advice.
    Doug Loeffler
    • 6955
    Re: C2 Rear suspension
    Doug, the rear axle support will need much more than a gentile tug, if its never been down in all these years you'll have to give it big a tug.( make sure supported well)
    Sorry have no idea on the trailing arm bushings w/o the tool maybe someone has made up something that will work.
    • Alan D.
      • January 1, 2005
      • 2053
      Do a search on Gary Ramadei - he has posted a link to a step by step for such a project. If these are not done correctly they have tendency to slip out and then you get to do all over again.
      See this one first;
      https://www.forums.ncrs.org/showthread.php?t=75270
      • Gary R.
        • April 1, 1989
        • 1804
        Hi Al
        Is this the link you're looking for?
        • Donald O.
          • May 31, 1990
          • 1593
          Originally posted by Doug Loeffler (51544)
          H
          Doug Loeffler
          Doug,
          I used a 6' persuader.
          I only loosened the two attaching crossmember bolts about 1 1/2 turns and kept the floor jack under the center sention about a 1/2" below. You'll know when the cushion releases from the sombrero of the crossmember.
          Don
          • Gary R.
            • April 1, 1989
            • 1804
            If you're pulling down the diff then this thread my also help. I wrote it a few years ago and no longer send out the rebuild paper as some took advantage of this in the wrong way.
