Need info on 63/4 Strut Rod heat shield configuration - NCRS Discussion Boards
  • Tracy C.
    • July 31, 2003
    • 2739
    Looking for some info on the strut rod heat shields. I found this pic in the archives posted by Wayne Midkiff that shows the shield. Can some one provide dimensions and a thickness? I assume the piece is steel and is welded to the mounting bracket. Is it tack welded on the corners or sides or is it spot welded?
    Also, should the shield be a flat sheet or was it originally bent to kinda sorta match the contour of the bottom of the mount bracket as the one in the photo is.
    I need to fab and install a pair on my July 63 car as they are missing.
    Thanks for your help.
    tc
  • Timothy B.
    • April 30, 1983
    • 5203
    Re: Need info on 63/4 Strut Rod heat shield configuration
    Tracy,
    On my 63 what was left was tack welded in the middle. I replaced mine with a piece of sheet metal and when I tightened the strut bolts tight they sort of bent round a little because the bolt compresses the bracket.
    • Tracy C.
      • July 31, 2003
      • 2739
      Thanks Tim,
      I'm guessing the shield is .030 thick. More or less?
      tc
      • Timothy B.
        • April 30, 1983
        • 5203
        Tracy,
        That thickness is probably about right. If you want I can get you a pic of the shields on my 63.
        • Tracy C.
          • July 31, 2003
          • 2739
          Thanks for the help Tim. I think I have enough to go forward here with your info and Wayne's pic.
