Which coil is correct- '63 w/340HP??? - NCRS Discussion Boards
  • Bill D.
    • January 1, 1985
    • 76
    I have a '63 with 340 HP and serial #7883 (end of Jan). Should I purchase an 087 or an 091 ignition coil to be correct. My old judging manual does not have any info on changeover VIN or date. Thanks for any info you can give me.
  • Donald L.
    • September 30, 1998
    • 461
    Re: Which coil is correct- '63 w/340HP???
    From what Ive read the 091 coil was used on all solid lifter engines in the 63 model year. The 087 coil supersede the 091 sometime mid year in 250-300 hp engines.
    • Tracy C.
      • July 31, 2003
      • 2739
      Bill,
      You need the 091 coil and a new 5th edition 63/4 J/G. Many of the errors were cleaned up with that release.
      tc
        • 15706
        Correct. Also, the 091 coil was mated to the 0.3 ohm ballast and the 087 to the 1.8 ohm.
        The 091 coil/0.3 ohm ballast have a propensity to burn points, particularly in cold weather.
        • Bill D.
          • January 1, 1985
          • 76
          Thank you all very much for your knowledge and help! I will also check the ballast resistor.
          Bill
