So i just got a replacement Rochester Q-Jet for my 71 350ci/270hp with the correct date code.
But its just the carb. No gasket, bolts, or studs. I think I have found the correct gasket at a local autoparts store, but no one carries the specific part number bolts (the ones that mount the carb to the intake manifold). So I was going to just get some other bolts to use, but I need to know the specs (i.e. thread, length, diameter, etc) to get the correct ones. Does anyone know the specs on the 4 mounting bolts/studs for the Q-Jet (p/n 7041213)?
Also this will be my frst carb install, and I was going to look through the Restorer archive to see if there are any articles on installing one, but does anyone have a procedure or advice?
Thanks for all the help!!
Chad
Chad
