is it a big block from the factory - NCRS Discussion Boards
  • Ewing M.
    Infrequent User
    • August 31, 1993
    • 9
    by what methods can you determine a 1965 with no paper trail is a big block from the factory
  • Don H.
    • December 1, 1981
    • 1487
    Re: is it a big block from the factory
    You would start with the 396 only features such as the battery on the driver's side (same as AC cars). The serial number would be another clue as they were introduced mid year (not sure what # they started). I am sure there are other items but if they wanted to "make" it a big block it could be done. Don H.
    • Wayne M.
      • March 1, 1980
      • 6414
      Among all of the C2 BB's, 1965 L78's would be the most difficult to purposely "build" with the intent of deception , because of the multitude of unique features, starting with the ones Don mentions.
      I've been meaning to jot down a comprehensive checklist for decades .
      The best way to start is with the Assembly Instructions Manual (AIM).
      • Joel T.
        • April 30, 2005
        • 765
        Hi;
        A couple of other things to look for... Check the rear end, the BB rears had special codes, also check the date on the rear, it should jive with the build date etc. It should also have the BB half shaft caps versus the "U" bolts found on SB cars. On the block, (assuming the "original" engine) check for the two gussets just under the intake... later blocks did not have them even though they had the same part number. In the rear, the sway bar assembly.
        The car should have all of these (including the battery on the left and the removable access panel for the battery AND no evidence of AC). It is possible (and maybe probably) that the original block is long gone... in that case stick with the other items.
        I went through this process myself on my '65 and depending upon what you have and don't have, putting one of these back into reasonable shape can cost $$$$.
        Have fun and good luck!
        Joel
        • Joel T.
          • April 30, 2005
          • 765
          One other thing, which I found to be true on my case.... Everything under the hood; wire harnesses, hoses, etc., were dried out and fairly brittle... probably owing to the greater heat generated by the Big Block!!!
          • Ronald L.
            • October 18, 2009
            • 3248
            The big and easy give away most the guys forget when turning a 66 into a BB is the fuel line. If the body has never been off (check rear area bolts for wrench socket marks), the fuel line is an easy give away.
            There is a list here somewhere.
            • Ewing M.
              Infrequent User
              • August 31, 1993
              • 9
              thanks
              in researching i find february sometime is when BB first appeared
              serial number of car in question indicates built late december
              appears to be factory SB
              • Tom D.
                • September 30, 1981
                • 2133
                There was a fuel line photo somewhere here also. BB makes a "sharper turn" from the frame (top) towards the fuel pump. Like 90 degrees.
                https://MichiganNCRS.org
                Michigan Chapter
                Tom Dingman
                • Ronald L.
                  • October 18, 2009
                  • 3248
                  The end is actually forward of the motor mount frame bracket so what happens is the SB fuel line has to be bent back at a funny angle to then swing and reach the forward position of the 427 fuel pump.
                    You're hitting on ONE of the 'acid' tests! Those early 396 cars (Feb & Mar) build are rather rare. YES, there were BB's built prior to Feb, but those which have been documented were some form of engineering test 'mule' and not true production vehicles for general public sale...
