1967 Automatic Choke - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1321
    I just installed a new carburetor and a new choke. It appears that I installed the choke properly ( the choke rod into the spring opening), but once the car starts, the choke remains on for quite a while. When I kick the gas pedal after the car is warm, it continues to run at a high rpm.
    Should the coil be wrapped around tighter? Any ideas will be helpful.
    Jerry
    Re: 1967 Automatic Choke
    Jerry
    Jerry -
    See the .pdf below.
    • Gerald C.
      • June 30, 1987
      • 1321
      John,
      What a great article. I'll try this when I get home tonight.
      Thanks!!!
      Jerry
