70 LS5 forged vs cast pistons - NCRS Discussion Boards
  • Steve G.
    • December 12, 2008
    • 192
    Re: 70 LS5 forged vs cast pistons
    The worst case bore measurement was 4.249", just under the lip at top of bore. Thanks for info on file fit rings. I was planning to put the engine back together myself once machinist cleans the block, verifies adequate piston to bore clearance, and hones it. Should I be checking end gap in the unworn portion of bore and what range should I be shooting for? Any tricks to filing them? Steve
    • Clem Z.
      • January 1, 2006
      • 9427
      the gap will be listed in the ring install instructions that comes with the rings. here is a picture of the ring filer you need
      • Steve G.
        • December 12, 2008
        • 192
        #18
        Thanks for all the replies. Steve
