Opinions on thie L-72 Stamp pad - NCRS Discussion Boards
  • Robert C.
    Infrequent User
    • June 20, 2010
    • 11
    I'm currently looking for a 66' L-72 Coupe and this is an engine pad stamp from one I'm considering. Input please on originality? Thanks!
    • 11669
    Re: Opinions on thie L-72 Stamp pad
    Do you have one cropped to show just the pad, or better yet one with much better resolution?
    When I download it onto my computer then try to magnify it, it's hard to make any calls on it due to the resolution.
    • Larry M.
      • January 1, 1992
      • 2701
      Robert:
      Need better picture/resolution as Pat states. Based on what I can see from your picture, it does NOT appear to be factory typical. I would proceed carefully. Check the block casting number and casting date carefully. Has this engine ever been rebuilt?? When, and by whom??
      Again, a better picture is needed to make a better call.
      Larry
      • Steven C.
        • April 30, 2002
        • 199
        Agree w/Larry. Broach marks not typical but need a better pic.
        • Pancho T.
          • July 31, 1993
          • 238
          Originally posted by Larry Mulder (20401)
          Robert:
          Larry
          I agree.Still need better pictures but as Larry says it does not look typical factory broach to me
          Pancho
          • Robert C.
            Infrequent User
            • June 20, 2010
            • 11
            Thanks guys, see what I can do about a better pic.
            • Ronald L.
              • October 18, 2009
              • 3248
              Is this car located in MI by any chance???
              • Robert C.
                Infrequent User
                • June 20, 2010
                • 11
                No, this car is in Maryland:
                I just missed out on a 66' L-72 in the Detriot area, must have been the real deal..sold in 2 days.
                • Ronald L.
                  • October 18, 2009
                  • 3248
                  Re: Opinions on this L-72 Stamp pad
                  That one is headed to Cali, I missed evaluating it for being on the east coast. As the guys have asked, need to get a hi rez pic and then crop out the stamp pad. Might have to email the hi rez pic as this board limits resolution to very low level...
                  • Ronald L.
                    • October 18, 2009
                    • 3248
                    Here is the pad cropped, sharpened - but still low rez.
                    6 million dollar question - when was the pad stamped at Tonawanda?
                    Before head install or after?
                    This one looks like it was stamped before notice the numbers are mostly under the head plug and I'm not so sure about that...
                    • Ronald L.
                      • October 18, 2009
                      • 3248
                      As above, need to get all the casting number details, scrape them to be sure they are not bondo, if they let you.
                      "Looks like" a "spec built" car.
                      Ask about a front end hit...
                        • 11669
                        They're supposed to be under the plug.
                        • Joel F.
                          • April 30, 2004
                          • 659
                          Even with the bad pic you can see the broach marks are not parallel.
                          • William G.
                            • December 1, 1988
                            • 138
                            So.........you guys are saying the blocks were stamped before the heads were installed.........or am I missing something here? So.....that early in the assembly of the engine they knew what car (vin number) the engine was going into? Did this early stamping of the block pad exist on the small block also? And I'm no expert (and NEVER pretend to be), but the broach marks don't look to me to be original. And since those engines came form Tonawanda it would appear even more so a surprise that the stamping was done before the heads were installed.
                              • 11669
                              Big blocks had the assembly date and code stamped on them before the heads were installed. Small blocks did not. So, on a big block, seeing the stamping "blocked" by the plug in the head is not unusual.
                              VIN stamping derivatives were all added at St. Louis (and later BG).
                              I won't judge this stamp or pad based on a low resolution photo. That's not fair to the buyer, seller or the car.
