Sorting out the last few problems of my frame-off restoration. Driving to Charlotte Tuesday for Top Flight judging (God willing).
Here is a picture of my rear-end and spring set-up. Car has had a fiberglass spring and modern support rods for many years; I know, sorry.
My problem is this: with the car moving, the right side outboard half-shaft makes slight contact with the spindle flange when it turns causing a "bump" at one spot in the rotation. Spinning the wheel with the car on jack stands you can actually see the trailing arm lift as the end of the half-shaft makes contact as it comes around.
With a floor jack placed under the end of the spring lifting the whole wheel assembly, there is no contact at all, as the half-shaft rotates freely. Just had the car aligned recently and it tracks beautifully.
Unless I have re-assembled something improperly, what can I adjust to raise the level of the half-shaft slightly so that there is no contact as it turns. By the way, the left side half-shaft does not have the same problem and both half-shafts looked straight when I removed them to replace all the U-joints.
Thank you,
Frank O'Donnell
Charlottesville, VA
Hope to see you in Charlotte!
Thank you,
Frank O'Donnell
Charlottesville, VA
