61 Horn Mounting Bolts - NCRS Discussion Boards
  • Dennis C.
    • June 30, 2002
    • 884
    Hi All,
    The JM indicates the horn mounting bolts for a 1961 generally have a head marking of "T" with an external tooth star washer. It doesn't give any other description.
    Has anyone every seen any other head markings (L or TR) for these bolts?
    Would the correct bolts have an indented hex head (untrimmed) or a cap bolt?
    I appreciate the assistance.
    Thank you.
    Dennis
  • Gary C.
    Administrator
    • October 1, 1982
    • 17771
    Re: 61 Horn Mounting Bolts
    Dennis, if the horn mount bolt is the same as '57's part # 120229. Head marking could be WB1C, UR or plain hex head 5/16" x .625" long. Part # also used in seat belt anchor for '57's. If part # from '61 AIM not the same, post the bolt part # and will see if I can find the info for you. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Dennis C.
      • June 30, 2002
      • 884
      Gary,
      The '61 AIM indicates a part number of 122007 for the bolt and number 178537 for the washer.
      Thanks for checking.
      Dennis
      • Gary C.
        Administrator
        • October 1, 1982
        • 17771
        Dennis, '57 bolt info shows 122007 bolt 5/16" x .75 hex head with WB1C, UR, L, TR small E or T head markings. That bolt is used in lots of different places in '57. Gary....
        NCRS Texas Chapter
        • Dennis C.
          • June 30, 2002
          • 884
          Gary, great, thank you. This information was a big help.
          Thanks again.
          Dennis
