56 Original Power Window car? - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1922
    My 56 (# 2117) was originally a two four, powerglide, parking brake warning, courtesy lights, power top, hard top, heater, radio, windshield washers optioned car.
    Enough of the original equipment remains (in some cases all of the original equipment remains) to confirm these options.
    Last night, for the first time, I noticed two holes drilled in the top of the firewall on the passenger side. This is original, unmollested fiberglass in this area. The location is precisely where the power window relay would have been mounted.
    I cannot find any other indication that this car originally had power windows. The window regulators in the doors are for manual windows.
    So, did the factor drill the power top relay holes for all cars, regardless of window type, or is this a reasonably good indication that my car had power windows originally.
    I didn't think to check and see if anything had ever been screwed into those holes. I'll do that this evening.
    Thoughts?
  • Michael A.
    • June 30, 1986
    • 68
    Re: 56 Original Power Window car?
    Hi Ed,
    I believe the power top also ran thru that relay. The wiring for my no. 10 car is all wadded up in a box or I would say for sure. Some of the other members might be better able to advise you.
    Later Mike
    • Jerry B.
      • August 31, 1994
      • 416
      Hi Ed, I To Have An Original 57 Power Window Car. There Maybe Several Other Ways To Determine Original Equipped P/w Option. Awhile Ago, I Replaced The Wiring Harness For P/w. I Noticed Two Things: One:there Were Two Screws That Held The Conduit To The Front Door Leaving Two Holes. Two: There May Be Traces Of The Retainers Used To Secure The Harness To The Inside Of The Fiberglass Door Panel. Maybe Your Door Was Replaced Over Its 52 Years Life. These Were My Observations.
      • Gary C.
        Administrator
        • October 1, 1982
        • 17771
        Ed, holes are for the power top and power window (if so equipped) circuit breaker. Info's in the JM. Gary....
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Edward M.
          • November 1, 1985
          • 1922
          You assume I actually read the JM....
          Thanks, that does explain it.
          • Roy B.
            • February 1, 1975
            • 7044
            You'll see two holes for a relay if it had
            1 power windows
            Or
            2 power top
            Other wise no holes
            If it did have power windows you'll have holes in the door post area that the wire conduit passed into when you close the door and the (door) were the power switch is located will have a square cut out with a metal box.
            pic. is 56 PT parts but relay the same
            • Dan D.
              • November 5, 2008
              • 1323
              You say your car has a power top (most 56's did), so the relay and wiring should still be there for the top. Trace out the top wiring to find how it gets its juice. -Dan-
                Ed -
                Here's the power top circuit breaker on a '58.
                • James O.
                  • November 1, 1985
                  • 160
                  For 1959, if the 2 mounting holes are there but only appear to be 1/32" dia like no screw was ever inserted, does that mean car had power top and/or windows or are they just pilot locator holes that were put on all bodies?
                  • Mike E.
                    • February 28, 1975
                    • 5141
                    Pilot holes for all cars up through 62. Generally a couple of drops of resin on those holes close them up on non-power option cars. Sometimes that was done very sloppily, other times it's unnoticable that it was done.
                    • James O.
                      • November 1, 1985
                      • 160
                      thanks. that explains it.
                      • David A.
                        • July 31, 1999
                        • 147
                        i do have this circuit breaker on my firewall
                        without any wires attached to it!
                        i do not have power windows
                        but i did have a power top.
                        Q the wiring diagram shows a tan wire coming off
                        this breaker for the power top.
                        where does this tan wire go thru the firewall?
                        i see here the red wire goes thru the large grommett
                        nearest the circuit breaker.
                        i've looked at many pictures of the firewall on the
                        C1 registry site, and all the tan wires off this CB
                        go down somewhere below the wiper motor
                        thanks
                        iowa
                        • Jim K.
                          • March 1, 1978
                          • 49
                          Hi Dave; The tan wire goes from the circuit breaker , passes through two wiring harness clips under the wiper motor, then goes through the 4-hole
                          grommet in the firewall just above the ballast resistor, then attaches to the power top switch under the dash. This grommet also has a cable for the wiper motor and the oil pressure line passing through it. If you have an assembly manual you can find the tan wire routing on page K232. Hope
                          this helps. Regards, Jim
                          • David B.
                            • July 31, 2004
                            • 330
                            I believe that with the power top 56-57's you will also find two holes drilled in the underside of the dash where the switch was attached. I believe these were only drilled for the power top cars, but am open to correction on that.
                            Dave, 1969 427, 1957
                            Previous: 1968 427, 1973 454
                            • David A.
                              • July 31, 1999
                              • 147
                              thanks for the help
                              i just got my AM today!
                              and it does show the route of the tan wire
                              but shows it going thru a 2 hole grommet;
                              and it is unclear just where the firewall hole is.
                              i'll put it thru the 4 holer
                              iowa
