Mid year rear suspension - NCRS Discussion Boards
  • Karl K.
    • November 17, 2008
    • 92
    Why on some midyear Corvettes do
    they sit high in the rear? It seems to be on restored cars
    from what I have seen.
  • Rich P.
    • January 12, 2009
    • 1361
    Re: Mid year rear suspension
    Karl,
    Repop rear springs. Both 7 and 9 leaf springs sit high when new
    Rich
      Karl -
      Because many of them have replacement rear springs (from many sources), and few are made properly to provide correct original ride height using the original spring end link bolts.
      • Karl K.
        • November 17, 2008
        • 92
        I'm looking at a 65 coupe that is sitting up in the rear about
        3 inches, how easily is it fixed?
        • Bob R.
          • June 30, 2002
          • 1596
          The ride height is controlled by the spring, the bushings and the bolts that connect the spring to the frame. The most likely cause for the ride height being too high is an incorrect spring. It is difficult but not impossible to locate an original spring in good condition. There are also some vendors that make a spring very close but not exactly the same as the original. It is not a very difficult job to change out the spring and the springs are not that expensive under $200. With a correct spring and bolts the ride height should be correct.
          • Bill M.
            • April 1, 1977
            • 1386
            Some spring shops have the capability to recamber (de-arch) the rear spring that is in the car now. This will drop the rear end and you don't have to buy a new spring.
            • Stan E.
              • April 30, 1991
              • 383
              Many mid-years have weak front springs
