finally painted - NCRS Discussion Boards
finally painted
  • Roy H.
    • January 6, 2009
    • 40
    finally painted
    trophy blue.
    working on the control arms now. Guess i will have to make a bushing install tube ? Is that the best way to go ?
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: finally painted
    Roy,
    You don't need the install tube for new bushings.
    1) Just wipe a little wheel bearing grease on the inner and outer case of the bushing.
    2) Start a bushing on one end of the control arm, then insert the shaft into this bushing
    3) Start the other bushing on the opposite side and get the shaft started into that bushing.
    4) Start bumping the bushings into place with a rubber mallet. Alternate the bushing you are bumping until they are both home.
    It's best to do this with the control arm shaft perpendicular to the work bench. When finished, you should be able to rotate the control arm shaft without too much effort. The grease is the key here. Don't get carried away with too much, but don't try it without it either.
    tc
      • 6955
      Re: finally painted
      Roy, car looks great,really like that color, is the darker blue a base coat before the trophy blue?or the color it was before painting . as Tracy say a mallet and if you have a 1/2 drive socket that is about the same outter diameter of the bushing it helps drive the bushing in also.
      • Tom H.
        • December 1, 1993
        • 3440
        Re: finally painted
        I have no clue on the control arms, but I love that color !!!
        Tom Hendricks
        Proud Member NCRS #23758
        NCM Founding Member # 1143
        • Steven T.
          • February 18, 2010
          • 50
          Re: finally painted
          looks great but of course we need to see many more pictures!
          • Tracy C.
            • July 31, 2003
            • 2739
            Re: finally painted
            Roy, car looks great. as tracy say a mallet and if you have a 1/2 drive socket that is about the same outter diameter of the bushing it helps drive the bushing in also.
            Great tip Ed with the socket. I've also used a 1 1/4" iron pipe nipple with a 1 1/4" iron pipe cap screwed onto one end to substitute for the socket. This size will fit nicely over the rubber and transfer the hammer force directly to the metal sleeve of the bushing.
            You can buy these items for less than $2 at your local hardware store.
            tc
