67 battery hold down and bolt confirmation - NCRS Discussion Boards
  • Dereck S.
    • July 30, 2008
    • 244
    Need help confirming that I have the correct battery hold down clamp and bolt for my 67 non-air car. Removed the clamp and noticed a stamped "B" on it. The bolt is pointed with a large "C" with three lines emmanating from it along with a captive washer. I suspect they are correct but could use confirmation. Also, would semi-gloss black be correct finish? Please see attached picture.
    Dereck
  • Ray G.
    • May 31, 1986
    • 1189
    Re: 67 battery hold down and bolt confirmation
    Dereck
    Hello Dereck;
    Looks like what is on our '67
    Interested to see our contributions to your question.
    Ray
    I hope you dance
    • Dereck S.
      • July 30, 2008
      • 244
      Hi Ray,
      I've run across some clamps with a "K" stamped on them and was not sure what was correct. I know these battery clamps were used across the GM product lines. I also have seen a different part number for 68 and later cars GM#6270159. Based on the AIM the correct part number for a 67 is GM#3887588. Do you know what changed from 67 to 68?
      thanks,
      Dereck
      • Ray G.
        • May 31, 1986
        • 1189
        Hi Ray,
        thanks,
        Dereck
        Hello Derek;
        Cleaned ours off. Bolt head marking similar, but w/ an "e" in the center.
        The "K" or "I" on our is barely readable.
        Ray
        I hope you dance
