Power Steering on 66 L-72? - NCRS Discussion Boards
  • Robert C.
    Infrequent User
    • June 20, 2010
    • 11
    Was power steering available on a 1966 Coupe with the L-72 engine? I have a 65' and the 65' Judging guide, but am not sure about the 66'. Thanks in advance!
    • 43246
    Re: Power Steering on 66 L-72?
    Robert-----
    Yes, it was available. There was no ordering restrictions for N-40 power steering for 1966 Corvettes.
    • Mike Z.
      • 226
      Robert-----
      Joe, you are correct-I owned one in the past. FYI the pump pulley was cast, like the harmonic balancer pulley, unlike the stamped steel pieces on lessor HP rated motors.
      Mike Zamora
      #12455
        • 43246
        Mike Zamora
        #12455
        Mike-----
        All Corvette big blocks with power steering from 1965 to 1974 used the same 2 groove, cast iron power steering pump pulley, GM #3878245.
        Some 63-74 small blocks also used a cast iron pulley but it was a single groove pulley, GM #3834720.
        No Corvette after 1974 used a cast iron pulley for the power steering pump since there never was a cast iron pulley designed for use with the press-on style pump shafts used for all 1975-82 Corvettes.
