C2 clock bezel re-attachment - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    This post is for archival purposes (in the "for what it's worth" category).
    When I was putting my 63 clock back together, I found that re-attaching the bezel was an issue. There are 3 sets of 2 pins on the back of the bezel that were peened over originally to attach the bezel. After removing the peened part to get the bezel off, the pins are too short to re-peen. I checked the archives and found a post by some one with the same problem, and one of the replies suggested drilling and tapping the bezel for small screws. I tried that and it worked well. Here's the way I did it........ I filed off one pin in each set and put a punch mark in the center of where each pin was. The inside wall of the bezel is slanted, so I drilled the holes at about a 15 deg angle to make sure the bit didn't penetrate the inside wall. I used #3-48 x 1/4" machine screws. The bit size for tapping this thread is a 47 bit (I don't understand the nomenclature, but it is about 5/64"). Since the tap is tapered and doesn't cut threads to the bottom of the hole, I drilled the holes 5/16" deep so that when tapping I would get a full 1/4" of threads. (I used a drill press with a depth stop). I bought a #3-48 tap and tapped the threads by hand. The bezel is pretty soft (aluminum?). The bit and tap are very fine, so go slow and use some machine oil while drilling and tapping.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11325
    Re: C2 clock bezel re-attachment
    Steve, I think that was my post that you found. I used those tiny screws on our '63 clock when I replaced the lens and it worked out fine. I'm glad it worked for you as it did for me. I believe the bezel is made of pot metal.
    FYI, in my experiences in the past I have ground the tips of the tap flat and then given a very slight taper on the grinder to get in deeper. Tough on a #3 tap I know. FYI the screws I used were self threading stainless screws. I drilled the bezel as you did on the nubs after flattening with a Dremel I recall. I was nervous as you likely were, to not go too deep.
    Rich
    • Steve D.
      • February 1, 2002
      • 990
      Rich
      You must have had jeweler's training to tackle modifying that tap!
      steve
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11325
        Steve,
        Most of the training came from 2 places......one was many years in the electronics engineering arena probing microelectronics and state of the art semiconductor technology. That was the day job that supported the Night Job. The other came from the Night Job using microscopy to dig 5-micron fiberglass splinters out of my hands from working on old Corvettes!
        Rich
