I pulled the distributor out of my 1969 350/350 to change the vac can to a VC1765 for full time vacuum.  I found the dimple on the distributor drive gear opposite the rotor contact.  The engine starts and runs fine.  Should I change the gear to the correct side?  Will doing so make a difference in getting the car started or timed after reinstalling the distributor?  I was planning on sending the dist out to be rebuilt in the late fall.  Should I just put it back in and drive the car until I send out the dist?   Always a suprise with 40 year old cars.
Larry Merchantz
					Larry Merchantz
