C2fan clutch - NCRS Discussion Boards
C2fan clutch
  • Joe D.
    • April 30, 2002
    • 382
    C2fan clutch
    I have a March built 66 327-350. Should the fan clutch be dated? If so what would be a correct date? Thanks, Joe
  • William L.
    • February 18, 2010
    • 22
    Re: C2fan clutch
    My July 66 has a 25 June 66 dated fan clutch if that helps any........
    Bill Lutter
    • Ronald L.
      • October 18, 2009
      • 3248
      Re: C2fan clutch
      Might get more info from the fourm search, but Schweitzer clutches were dated along the flange as I recall and eaton not, may also be different by 327 vs. 427.
      • Peter J.
        • September 30, 1994
        • 586
        Re: C2fan clutch
        Joe, My 66 L-79 has a June fan with a May date, I can check for a day if you need it.
        Pete
        • Wayne M.
          • March 1, 1980
          • 6414
          Re: C2fan clutch
          This might help: According to the '65 TIM&JG, "earliest observed dates [on the Schweitzer clutches -- the ones with the spiral bimetallic coil] begin in mid [calendar] 1965." This would mean essentially all '66s and up with this manufacturer. [Square brackets are my additions].
          • Jack H.
            • April 1, 1990
            • 9906
            Re: C2fan clutch
            Something's wrong with this descriptive text... Eaton used the bi-metal actuating coil technology while Schwitzer used a flat bi-metal rectangle to control temperature compensation...
            • Rob M.
              • April 30, 2003
              • 657
              Re: C2fan clutch
              Joe,
              FWIW, my May 5th small block's fan is dated April 22nd (If I recall correctly). I would think one to four weeks preceding your build would be appropriate.
              Rob
              '66 327/300 Regional Top Flt
              '08 6 speed coupe
              • Wayne M.
                • March 1, 1980
                • 6414
                Re: C2fan clutch
                Right-on, Jack; brain gas on my part.
                • Joe D.
                  • April 30, 2002
                  • 382
                  Re: C2fan clutch
                  Thanks for the help. Any idea of what a used one would go for? Can they be rebuilt? Thanks. Joe
                  • Jim D.
                    • 2885
                    Re: C2fan clutch
                    The going price for a rebuild is $300 plus a one year wait.
                    • Joe D.
                      • April 30, 2002
                      • 382
                      Re: C2fan clutch
                      Can you recomend someone who rebuilds them?
                      • Jack H.
                        • April 1, 1990
                        • 9906
                        Re: C2fan clutch
                        Hey, I've been there too!!
                        • Peter J.
                          • 586
                          Re: C2fan clutch
                          Fred Olivia does them and been doing them for a long time but rumor has it his turn around can be a year or more. I haven't done business with the next guy but he has gotten thumbs-up from some people on this board. Vinny Catalano, Pampered Glass Corvettes, 67B Gooding Ave, Bristol, RI, 02809
                          • Harry S.
                            • July 31, 2002
                            • 5332
                            Re: C2fan clutch
                            Peter, I'm looking at Vinny's business card. He is at:
                            18152 Porsche Place
                            Spring Hill, Florida 34610
                            352 799 8613
                            401 339 6012
                            I had my clutch redone by Fred and it took 18 months. I looked at Vinny's work at the Florida Regional and the end result is closer to original appearance. I have no way to compare performance.
