67 427/400hp Starter Question - NCRS Discussion Boards
  • Stephen G.
    • January 1, 2002
    • 305
    My 67 BB (L68 - 400 HP) has a 1108400 starter with date code 3L85. I can only assume it's not original or correct for the car. Any thoughts or help decoding the 3L85.
    Steve Gansky
    Newtown, (Bucks County) PA
  • John P.
    • August 31, 1991
    • 94
    Re: 67 427/400hp Starter Question
    It is a replacement starter.Could the date code series be 3L8 5? That would indicate a November 8 1973 date.The 5 is an operator code.
    • Stephen G.
      • January 1, 2002
      • 305
      Thanks John. You are exactly right. It's 3L8 5.
      Also John does anyone have the spring steel wire retaining clamp that the judging manual talks about. I can't find it in the AIM either.
      Steve Gansky
      • Jack C.
        • September 30, 1992
        • 1090
        Paragon 1504 for the clip.
        Jack Corso
        1972 Elkhart Green LT-1 Coupe 43,200 miles
        Top Flight 1994, 2018 & 2021
          • 43273
          Stephen-----
          While not original or correct for any 1967 Corvette, the GM #1108400 starter is a correct functional replacement starter for your application. The 1108400 was also used in PRODUCTION on many 1969-74 Corvette big blocks.
          Other than "numbers" and "dates" it is configured exactly the same as the 1107365 originally used for your application except for one feature. The 1107365 used field coil shoe screws with a slotted drive. The 1108400 used field coil shoe screws with phillips (cross recess) drive. Those are EASILY changed.
            Also does anyone have the spring steel wire retaining clamp that the judging manual talks about. I can't find it in the AIM either.
            Steve -
            See section L36, sheet A16, item #2 for the clamp.
