I want to thank everyone who responded to my 8 different questions about the 73'/74' judging guide as it relates to my May built 74' L48 convertible with optional hardtop. I found the judging guide very helpful with only these 8 items being questioned as I went through the review. Here is a summary of the responses:
1. Open ended wrench for hardtop likely not supplied with car. Judging guide likely in error.
2. Trim ring card likely supplied for early build 74's and then deleted as per AIM. No evidence of a radio instruction card ever being supplied. Judging guide needs to clarify/correct.
3. Yellow tag on tube from valve cover to air cleaner apparently exists - still would like to see a post with a picture. Unclear if any vendor is making a replacement
4. Engine suffix label exists - unclear if any vendor is making a replacement
5. Timing plate is spot welded to cover - Judging guide is in error.
6. Power steering pulley is stamped steel on an L48 if you have AC - Judging guide requires clarification/correction
7. AC lines going forward - one is a rubber hose and one is metal - Judging guide is correct but difficult to interpret unless one knows what a 73' system look like.
8. No coolant decal on radiator shroud/support area - Judging guide is in error.
