Location of radiator tag on a 1960 - NCRS Discussion Boards
  • Michael V.
    • July 31, 1990
    • 3
    I am finishing the work on my 60 in time for NCRS Convention. The 58-60 judging manual is very ambiguous about the location of the brass radiator tag that is spot welded to the top of the radiator. The manual says in the center and then in the same sentence it says left side. Can you help me clarify what the correct location & orientation for this tag should be. Thanks!
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Location of radiator tag on a 1960
    It was not spot welded but soldered ,and not on TOP but facing driver near the middle if it's not
    Aluminum
    • Michael V.
      • July 31, 1990
      • 3
      Thanks....we were actually able to find the original tag still on the radiator but buried under layers of paint and gunk!
