Engine Pulleys - NCRS Discussion Boards
Engine Pulleys
  • Gerald C.
    • June 30, 1987
    • 1311
    Engine Pulleys
    To all,
    I am building a 327/300 hp motor with P/S and no A/C. I'm trying to figure out the part #'s for the pulleys I'll need.
    Here's what I have:
    upper pulley # 1958095
    lower pulley #3849739
    P/S Pulley # 3960313
    How close am I to having the correct part #'s?
    Jerry
  • Timothy B.
    • April 30, 1983
    • 5202
    Re: Engine Pulleys
    Jerry,
    If it's a 63-64 car none of the #'s sound correct. The 63-4 300hp engines W/power steering have a two groove water pump (I believe 068) and two groove crank pulley that # ends in 043 and a add on single groove pulley (crank) for the P/S.
    The power steering pump used a stamped steel pulley but I can't remember #. Look in archives, I know the part #'s are there. The P/S belt runs from the crank to the P/S pump on the third groove closest to radiator..
    • Gerald C.
      • June 30, 1987
      • 1311
      Re: Engine Pulleys
      Sorry, I left out the fact that it is a May 1963 car
        Re: Engine Pulleys
        Gerald -
        The '63 Assembly Manual (section L-75/L-76, sheet 2.00) calls out #3770245 2-groove water pump pulley and #3766987 2-groove crankshaft pulley, and section N40, sheet 2.00 calls out #3751232 add-on crank pulley to drive the power steering pump, with #3770509 pump pulley.
        Note: The new 5th Edition '63-'64 JG says the add-on crank pulley for power steering goes behind the production pulley, but it doesn't - it goes in front of the production pulley.
        • Mark G.
          • March 1, 2001
          • 227
          Re: Engine Pulleys
          Gerald -
          This pulley set is for the '65 engines and the the first belt track is not used. These are standard groove .62" center line to center line pulleys.
          Base and L75 N40 only,
          3744043 2 Groove Crank
          3751232 1 Groove Add on for P/S
          3790356 2 Groove W/P
          3770509 P/S
          3871241 Alternator
          The part numbers may be different but the configuration will work.
          Mark
            • 43279
            Re: Engine Pulleys
            Gerald -
            John------
            ABSOLUTELY! In every single case. Period. How they ever came up with the notion that the add-on pulley is installed behind the primary pulley is beyond me.
            • Gerald C.
              • June 30, 1987
              • 1311
              Re: Engine Pulleys
              Thanks everyone. The information is much appreciated.
              Jerry
