Time to replace the exhaust on my 69 350/300 4sp.
The small block 1968 system has downtubes that expand the diameter from 2" at the manifold to 2.5". For 69 the system is 2" all the way back. Both fit on a 69.
Does the 2" -> 2.5" system provide a performance advantage over the 2" system?
Aluminized steel seems like the best material. I've heard that SS systems can be hard to seal at the clamps and increase interior heat.
I plan to purchase from either Corvette Central, Allens or Gardners. I can buy the Corvette Central system from my local Corvette Parts shop.
Any comments on material or vendor?
The car will be judged again and I know that there will be a deduct for the aluminzed pipes and also for the SS tips. I hate to lose my chrome tips, but back in the day the prior owner had work done by a muffler shop who did a sloppy job and welded the tips on the pipes. I may try to cut off the tips, clean them up and reuse them but the weld job slopped material on the chrome. Has anyone chrome plated the SS tips to avoid points loss?
even on the L88
