73/74 Judging Guide Items - item 4 - NCRS Discussion Boards
  • Robert S.
    • June 30, 2001
    • 230
    The rear of the passenger side valve cover is to have an engine suffix code label. Do any 74' owners with an L48 have this label and if so can you post a picture?
    • 11659
    Re: 73/74 Judging Guide Items - item 4
    These are rare, but do exist.
      • 43246
      Robert-----
      These labels were never designed to last. Their function was strictly in-plant, easy engine identification. Whatever adhesive was used was not, at all, heat resistant or in any way durable. So, in most cases, these stickers quickly fell off. The labels, themselves, were pretty much just plain paper so they weren't really very durable, either.
      • Robert S.
        • June 30, 2001
        • 230
        Thanks - I questioned this item in the judging guide only because I checked several of the aftermarket vendor catalogues and none sell this item although they do sell them for other (earlier) years. Also the judging guide specifies a decal on the fan shroud which I am about 95% certain is not correct as I believe the fan shroud decal was only used in 73' so that did not give me great confidence in the judging guide relative to decals in general.
        • Harmon C.
          • August 31, 1994
          • 3228
          You see the glue on the valve cover where the code was on low mileage cars and I have seen a few of the labels.
          Lyle
            • 11659
            There is at least one source of accurate reproductions, but it's not the catalogs.
              • 15609
              The only 1974 I have in my files is for a large motor, and that is not your question, however I do have a 1975 for your perusal. After seeing it perhaps you will understand why no vendor reproduces it.
              Well I would have posted it, but I already have and VBuliten will not let me do it again and I am dis-inclined to go through the BS required to re-post the picture.
              Here is a link to the thread about a 1975 discussion:
              https://www.forums.ncrs.org/showthre...11070&uid=7275
              You just might find what you want with a search. At the minimum you will learn about how each year and sometimes each engine had very different labels. Oh, and they sometimes changed during the year. Can't you see those engineers sitting around their drafting tables 35 years ago saying: "We'll get those NCRS geeks?"
              • Glenn D.
                • May 31, 2002
                • 137
                My 74' was built in July of 73' It never had a fan shroud decal. I saw that in the judging manual and thought it might be a mistake. I remember those valve cover stickers you are referring to, but mine are long gone. Sorry
                • Paul B.
                  • April 30, 1995
                  • 482
                  Originally posted by Glenn Demakes (38083)
                  My 74' was built in July of 73'.
                  Glenn, are you sure on this??? 1973s I believe were made up to August 9th of '73, if I'm remembering correctly. My 1974 #01950 was built B08(second month of production), Sept 8, 1973. First production month for even the earliest 1974 Corvette was August of '73.
                  • Glenn D.
                    • May 31, 2002
                    • 137
                    Sorry Paul. You are correct. July was when I ordered it. B21 build date.
