1967 voltage reg grounding - NCRS Discussion Boards
  • Keith G.
    • October 31, 2006
    • 316
    I had my reg grounded on the lower front and they told me that was wrong. So where and on top or under the reg. Thanks in advance.
    Re: 1967 voltage reg grounding
    Flip your copy of the '67 AIM to UPC 6, Sheet B4. There, you'll see the installation of the voltage regulator depicted. The drawing is pretty clear as to where the ground lug from the wiring harness attaches...
    • Dale C.
      Infrequent User
      • March 1, 1987
      • 26
      Keith
      The ground is bolted to the same place as the condensor is, to the rear of the voltage regulator, just under the cover. Dale
      • Keith G.
        • October 31, 2006
        • 316
        OK I got it figgured out, see you in Aug.
        • Michael H.
          • December 1, 1987
          • 732
          Originally posted by Dale Crosby (11181)
          Keith
          Dale,
          Does the ground go next to regulator housing first and then the capacitor bracket or the other way around ?
          Mike
            Originally posted by Michael Hanley (12271)
            Dale,
            Mike
            Mike -
            I don't think there's a documented "correct" way (the capacitor installation illustration in the U69 section of the Assembly Manual doesn't show the alternator ground wire), but the alternator-to-regulator ground is essential, so I put the alternator ground ring terminal against the regulator base, with the capacitor on top of it.
            • Michael H.
              • December 1, 1987
              • 732
              Mike -
              John,
              That's what I thought as well, thank you.
              Mike
