72 front end alignment specs - NCRS Discussion Boards
  • Gary L.
    • April 26, 2010
    • 18
    Ya I am still new at this,I am looking for the front end alignment specs for my 72 coupe with 350 engine and power steering. Thanks.
    • 6954
    Re: 72 front end alignment specs
    Gary, from 72 shop manuel, caster is + 2 1/4, camber is +3/4, toe in total is 1/4
    rear aligne, camber is +7/8, rear toe is+ 1/16
      The Shop Manual and Assembly Manual specs are for bias-ply tires; if you have radials, front toe-in should be zero-to-1/16" total toe-in, and rear toe-in should be 1/32" per side.
      • Gary L.
        • April 26, 2010
        • 18
        Thanks so much for the help everybody
