I have a '64 fuelie that someone put PS on so that required a 5 qt pan. I am going revert to manual steering as I want the car to be original. Question is which 6 qt pan is correct and if I can't get that how do I adapt later version pan?
From memory, GM had at least three 6 qt(yes, I know, really 5 qt) small block pans, but since the pans don't have part numbers it is hard to tell them apart. I believe the difference was the radius of the pans, front & rear to accommodate different gasket thicknesses?? I tried a search of past posts but couldn't find anything helpful. I seem to remember that the original took a thin gasket; second version was thick & not sure about the last. I need to know the pan measurements- pan rim to the bottom of the radius for front and rear crank seals.
Will appreciate any help and info. JimB
