C-3 (1970) Shoulder Belt Guide - NCRS Discussion Boards
  • John S.
    • August 31, 1999
    • 7
    I know this question probably has been asked a 100 times but I can't seem to locate it in the search. I've seen the plastic shoulder belt guides in front of the slot in the seat, in the back, and inside...which is correct? I guess the plastic part that fits over the belt is designed to keep the end of the belt from slipping through the slot in the seat. Thanks
  • D S.
    • February 28, 2005
    • 1551
    Re: C-3 (1970) Shoulder Belt Guide
    In front of the holes in the seat bezels to keep the shoulder harness ends visible and easily accessible.
    • John S.
      • August 31, 1999
      • 7
      Thanks...I also found the answer and diagram on page K-119 in the 70 assembly manual. I had looked before but could not find it.
      • Reba W.
        • 932
        Be sure you install them correctly. I have judged many that were installed backwards. Since you have the AIM, that should be easy. Also they go on much more easily if warmed with hot water, the sun, or a hair dryer.
        • John S.
          • August 31, 1999
          • 7
          Thanks for the info. I did heat them up and was able to get them on correctly. Can't believe I've had this car 10 years and they were wrong the entire time...even had it judged at NCRS Waco and no one said a thing...Thanks again.
          • D S.
            • February 28, 2005
            • 1551
            Reba is quite right.....they can be almost impossible to slip on (or off) without making them most pliant. She said hair dryer, not a heat gun.
            • Reba W.
              • 932
              Did I judge it in Waco, Jim?
