69 Vacuum System - NCRS Discussion Boards
69 Vacuum System
  • John M.
    • December 31, 1997
    • 813
    69 Vacuum System
    What in the world is the vacuum switch on the tachometer for? I've owned this car for 12 years and am now cleaning it up and learning all kinds of things.
    John McRae 30025
    69 L71
  • Tom H.
    • November 30, 1993
    • 3440
    Re: 69 Vacuum System
    Isn't that the wiper door solenoid ????
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Roger O.
      • September 7, 2009
      • 209
      I agree. The solenoid shuts off and bleeds the vacuum going to the wiper door relay telling the door to open.
      • John M.
        • December 31, 1997
        • 813
        Thanks guys, but how does the tachometer fit into this picture. The wiper door is controlled by a vacuum switch on the headlight switch and the over-ride. Is this other switch just mounted on the tach for convenience? I haven't got that out of there to see what the connection is.
        • Dick W.
          • 10483
          Just mounted there for convience. Should have two vacuum hoses and one wire attached.
          Dick Whittington
            • March 31, 1990
            Dick is on the money, again! The tach was simply a convenient location nearby the point of entry through the firewall for the vacuum system's Control Path hose AND not that far from the WSW electrical switch in the center console.
            So, that's why the electro-vacuum relay is mounted on the back of the tachometer housing... It has NOTHING to do with the tach!
            • John M.
              • December 31, 1997
              • 813
              Thanks guys
