03 anniversary convertible TPMS - NCRS Discussion Boards
  • David P.
    • June 20, 2010
    • 9
    I bought a 2003 anniversary corvette convertible new. At about 1500 miles I put on chromed Z06 wheels and tires. I just changed back to my original tires and wheels at 8,100 miles. The tire pressure monitors aren't reading out. In fact they don't even show in the car's computer. Is there a reset of sorts needed to activate the TPMS? All help appreciated
    • 15616
    Re: 03 anniversary convertible TPMS
    Yes, the car's computer has to be "introduced" to the new/different tire pressure monitors. It also needs to know which monitor (by serial number) is at which wheel position. This can be done electronically.
    I am not sure how this process is done for your car, but that information should be in your Owner's Manual. My 2008 requires a special tool to do the job, but some earlier monitors can be activated with a strong magnet. I am not sure which type your car has. consult your Owners Manual.
    • Tom H.
      • December 1, 1993
      • 3440
      This issue comes up all the time on the C5 Corvette forums. Here's the method we use. It is simple to do when you know how !
      1) Turn ignition on
      2) Press "Reset" button in
      order to clear any IPC display warning messages
      3) Press and release
      the "Options" button on the DIC to scroll through the
      display
      options until the IPC display is blank
      4) Press and hold the DIC
      "Reset" button for 3 seconds
      5) Press the "Options" button
      again until TIRE TRAINING message appears
      6) Press "Reset" button
      until the IPC "Learn L Front Tire" message appears in
      order to
      begin the programming
      7) Install the J41760 Tire Pressure Monitor
      (TPM) System Programming Tool
      (large magnet will do) over the left
      front valve stem
      8) The horn will sound, indicating the left front TPM
      sensor is programmed
      (if this takes more than 15 seconds, pull magnet
      back and try again, it will
      give you three tries. Then you must start
      over)
      9) When the horn sounds, proceed to program the next TPM sensor
      in the
      following order as directed by the IPC messages:
      -Learn R
      Front Tire
      -Learn R Rear Tire
      -Learn L Rear Tire
      Programming can be canceled by turning ignition off, waiting 2
      minutes with
      no sensors being learned, finishing all 4 wheels or
      through the DIC.
      If the programming is canceled with less than 4
      sensors learned, it will only
      accept the codes programmed up to that
      point.
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Peter M.
        • April 8, 2007
        • 570
        David - As you know, the tire pressure sensor units have a battery inside of them which will slowly lose its power over a several year period. The sensors are designed to be a throw away item, BUT the batteries can be replaced at little or no cost. Attached is a write-up on how to replace the lithium batteries in your TPMS sending units.
        FWIW
