1960 exhaust mainifold dressing - NCRS Discussion Boards
  • Valeria H.
    • July 27, 2009
    • 463
    What product will return rusted exhaust mainifolds to the "close to" oringinal color?
    I did a search on the achives and came empty?
    Valeria
    Valeria Hutchinson
    Past Chairman of the Carolinas Chapter
    1960 Roman Red w/ White Coves -"Bella"
    2005 Millennium Yellow 6 speed 400 HP - "Trixie"
  • Keith R.
    • August 31, 2001
    • 675
    Re: 1960 exhaust mainifold dressing
    Try Calyx manifold dressing. It's not permanent so you have to reapply it from time to time. Wear latex gloves too as it is a little messy.
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
    • Valeria H.
      • July 27, 2009
      • 463
      The manifolds are rusty. Do I need to scrub the rust off before the application.
      Valeria
      Valeria Hutchinson
      • Glenn D.
        • May 31, 2002
        • 137
        I tried to post a picture of my exhaust manifolds with freshly applied calyx , but the system said I had already posted that picture previously. Can you only post a picture once ? If your manifolds are rusty , just brush them with a wire brush to remove any flakes and apply the dressing.
        • John F.
          • March 23, 2008
          • 2423
          I applied that dressing to mine on the car. Used an old toothbrush and it went on pretty easy. Looks real good when done, but will get your hands dirty any time later.
          John F
          • Scott S.
            • September 11, 2009
            • 1961
            Glenn,
            I run into this problem frequently. If you need to post the same picture again, try running it through a filter in your picture editor program and then save it to a different file name before uploading to the forum. I just hit the "quick fix" button, it does almost nothing, but changes the picture (i.e., contrast, brightness) just enough that the forum software sees it as a "new" picture, and will therefore allow you to post it.
            • John D.
              • December 1, 1979
              • 5507
              Valeria
              Valeria, I assume you have the judging manual for 58 to 60 but I don't know.
              I have the 4th edition but I think there is a later one.
              Anyhow on a '63 the exhaust manifolds were on the engine when it was painted orange.
              Your 60 would be the same.
              See section 12. "Manifolds were installed at point of engine manufacture (Flint) and were painted engine color (either full or partial.)
              I realize it's not practical to paint them Chevy orange right now though.
              So do what most do. Remove them, blast the crap out of them and them paint them with heat proof paint. I am not up on the brands. JD
              • Jack H.
                • April 1, 1990
                • 9906
                As mentioned, the exhaust manifolds were painted Chevy orange along with the engine. The rust that's present and any obvious surface pit, constitute a Condition issue.
                So, if you simply remove the manifolds, gently media blast them, and apply a fresh coat of Chevy orange, you should get full credit on the Originality side of the ledger. To the extent that there's OBVIOUS rust/pit damage, expect to lose some points on the condition side of the ledger.
                Later Corvettes shipped with unpainted exhaust manifolds and these are often the target for a cast iron 'looking' coating (like Calyx). But, Calyx once it's 'set' by running the engine and 'cooking' the coating is still OBVIOUS to a savvy judge--it represents a foreign FINISH that's easily distinguishable from raw cast iron. Hence, a 20% Originality deduction.
                Perhaps, you could use Calyx (it's a reasonably thick slurry) to strategically fill rust/pit damage and then shoot Chevy orange over it (once it's been 'cooked') as a Condition compromise...
                But, only YOU or your restorer can assess how well your existing manifolds will clean up via basic media blast when it comes to surface pit/wear considerations.
                  Valeria -
                  As I recall, judging (which requires burnt orange paint on the manifolds) isn't in your plan for the car, and you just want them to look nice. If that's what you're after, they should be bead-blasted lightly to knock off the rust, then painted with Seymour hi-temp manifold paint or Eastwood's "factory gray" hi-temp manifold paint. Then they'll look nice, and won't have Calyx on them that never cures and will rub off on anything that touches them.
                  • Valeria H.
                    • July 27, 2009
                    • 463
                    John,
                    Thank you for your response. I was chrinsing on orange paint response. This was worrisome. Your response seems far more palitable.
                    Valeria
                    Valeria Hutchinson
                    • Valeria H.
                      • July 27, 2009
                      • 463
                      Thanks to all who responded. There were several e-mails regarding ceramic coating which I do not think I have time to get completed before the convention.
                      I really like the idea and will probably have this done after the convention.
                      Thanks again!
                      Valeria
                      Valeria Hutchinson
