About a 3rd of the ear is broken off where the tension bolt goes, i do not have the broken piece. Can this be repaired? 1100884 0A30 61A
Alternator case repair
Re: Alternator case repair
That's a tough part to come by! I'm sure it can be repaired. But, the how, different alternatives, cost, and detectability aspect needs to be researched before you commit. I agree that John Pirkle is an EXCELLENT resource to consult with on this one!- Top
EASY! If you have access to a machine shop.
I have a 950 alternator that had the same condition on my 71. I machined away the broke part, providing a pocket for an insert (that i subsequently made) the insert was machined to the same configuration. Welded it on, dressed it, very light glass bead. I Drilled and tapped the new hole for a helicoil. It is 99% undetectable. Pm me and I can make a sketch. I should have taken pictures for a tech article
Pete Bergmann
2005 - 2013 C6 National Teamleader- Top
