67 390hp (+) battery cable routing - NCRS Discussion Boards
  • Carl F.
    • June 30, 1996
    • 11
    Hello,
    On '67 bigblock cars, specifically a 390HP w/o ac, does the positive cable run up through the heat shield or is it routed on the outside?
    Any help would be greatly appreciated!
    Carl
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 67 390hp (+) battery cable routing
    Cabling is outside of the heat shield thru clip on firewall below heater box and then under starter solenoid clip to terminal on solenoid
