My lh rear stop light wont work. It had been working for ever but it broke lose, not attached to the fiberglass rear. when I removed lh rear tail light assembly the pigtail had pulled loose. I reconnected, but while looking at wireing I see where there is a ground connection that has no place I can find to connect to metal. Looking at manual, it shows it connecting to studs on assembly, with a nut holding behind fiberglass. What am I seeing wrong, how can ground work against fiberglass?
Help
Help
