I've spent a whole lot of time trying to sort out this clip issue and compare it to what the vendors sell.
I've checked the archives and wanted to varify the clip finish for a '73. It looks like it is:
GM 3977096 front x member(#1) brake cross over zinc*
GM 3976010 front left frame-first 2 for brake black phosphate
GM 3976009 left frame kick-up vapor tube black phosphate
GM 3923695 left(brake and vapor)
and right(fuel and return) frame zinc
GM 125921 fuel line rubber hose right side at tank zinc*
GM 3976011 #3 X member -outboard brake black phosphate
GM 3945439 #3 X member -at midpoint(clamp clip) zinc
The GM numbers are from the '73 AIM. The*means that I can see reminants of zinc on my samples. The other info I got from this forum, most notiable Chuck S.
I've taken my original GM and traced them on graph paper(1/8"per square). I've attached this to this post. I was confused as to what the GM profile was when comparing to what the vendors sell. If anyone want the PDF, PM me.
Can someone varify the finish for me?
