1968 Key Warning Buzzer - NCRS Discussion Boards
  • Kurt B.
    • July 31, 1996
    • 971
    Where is the buzzer located that warns of the ignition key being left in the ignition?
    Are replacements available?
    Can the existing buzzer be repaired or restored?
    Mine works intermittently and is very faint and hard to hear
    Thank you
    Kurt
    #26406
  • Pat M.
    • April 1, 2006
    • 1578
    Re: 1968 Key Warning Buzzer
    Kurt, if 68 is the same as 70, the buzzer itself is part of the horn relay, located on the left side of the engine compartment near the fender well. As of a couple of years ago it was still available from GM, although I'm not sure how well it may match a production piece. I'm also not sure if originals can be repaired/rebuilt.
    The buzzer switch, again if it's the same as 70, is in the steering column. NOS tilt and non-tilt switches were available from Dr. Rebuild as of a year or so ago.
    • Kurt B.
      • July 31, 1996
      • 971
      Pat,
      Thanks for the info.
      As regards the switch, my ignition key switch is mounted on the dash in 68 so would I still have any type of other switch in the steering column as well?
      My column is telescoping but not tilting.
      Kurt
      • Pat M.
        • April 1, 2006
        • 1578
        Kurt, very good question about the buzzer switch - I forgot that the 68 ignition switch was located on the dash, so I doubt the buzzer switch is located in the steering column. But I'll have to defer to the 68 experts on that one. Good luck.
        • James H.
          • February 22, 2007
          • 130
          Kirt,
          Just replaced mine this spring. Pretty sure I got it from Paragon for like $60.00.. Not as loud as my original and it its located on drivers side fender well behind the voltage regulator. Make sure its the right one when you get it, my 1st relay didn't have enough connections so had to sent it back and wait for them to send me the correct one. Let me know if you need a picture of anything.
          Jim
          • Peter L.
            • May 31, 1983
            • 1930
            Kurt - The buzzer is in the horn relay; but it is the key switch that actuates the buzzer so you'll want to do some trouble shooting to determine the source of the problem. Pete
            • Kurt B.
              • July 31, 1996
              • 971
              Jim,
              Would welcome the picture so I know what to look for
              Kurt
              • Kurt B.
                • July 31, 1996
                • 971
                Peter,
                If it is the horn relay, is that the one located in the large shift console just ahead of the ashtray and to the right of the shifter?
                Kurt
                  • 43242
                  Originally posted by Kurt Bunting (26406)
                  Peter,
                  Kurt
                  Kurt-----
                  No, that's the wiper relay. The horn relay is located on the driver side fender well. You will note a fairly large gauge RED wire connecting to it.
                    Plus, to add on to Joe's advice, the '68 horn relay is a one year only beast (1115862) but it's functionally similar to the '69-70 relay (1115890). An extra lead wire connects to the bottom side of the relay and that's the key minder circuit.
                    This wire runs through the engine harness to the cockpit via the firewall plug-in and on to the ignition switch. When the key is left in the ignition switch and the door opens, contact closure to ground completes the circuit causing the buzzer inside the horn relay to sound...
                    • Kurt B.
                      • July 31, 1996
                      • 971
                      Thank you one and all.
                      I will add this to the list of things to try to do this weekend.
                      I appreciate the input as always,
                      Kurt
                      • James H.
                        • February 22, 2007
                        • 130
                        Here you go.. mines got some 40yr old dirt and grime around it.
                        Jim,
                        Kurt
                        • Kurt B.
                          • July 31, 1996
                          • 971
                          Thank you Jim
                          A picture is worht a thousand words.
                          I will look for this thing tomorrow
                          Kurt
                            Here's what the real McCoy Delco 1115862 part looks like. The 'trick' here is the clear translucent plastic insulator that surrounds the bottom terminals and extends across the relay's side bar B+ terminal. Age, temperature, and exposure to UV cause this plastic to discolor (turn brown), become brittle and then to flake apart.
                            Finding one that doesn't have age/condition issues is the real trick! The same applies to the Delco 1115837 horn relay used in '66-67...
                            What you can't see from this side view is the '862' emboss on the relay body. This is one of those originality issues savvy judges look for when judging!
                            • Dan M.
                              • March 6, 2009
                              • 157
                              I thought the 1115889 relay was for 1968 not the 862 ? Am I confused (again)?
