1974 Distributor - NCRS Discussion Boards
1974 Distributor
  • Jeff C.
    • September 30, 1997
    • 233
    1974 Distributor
    When installing the drive gear on the distributor shaft it can be installed in 2 positions 180 degrees apart. There is a dimple on the bottom shaft of the gear and I read some where that the dimple should be aligned with the rotor firing tip. Can't find the article now but does anyone know if this is true? Thanks
    Jeff
  • James B.
    • March 1, 1985
    • 217
    Re: 1974 Distributor
    Yes, the dimple should be indexed with the rotor tip.
