1955 guys? - NCRS Discussion Boards
1955 guys?
  • Roy B.
    • February 1, 1975
    • 7044
    1955 guys?
    I know this might be asking only two people here having a 55 but which is the 55 Corvette manifold.? And here is the two exshaust heat risers one first design and second design . Any comments
  • Ray G.
    • May 31, 1986
    • 1189
    Re: 1955 guys?
    Hello Roy;
    Have one of each manifold.
    They both seem to have the same casting number 3704781.
    The non-indent manifold could be 3704791.
    So, what is what?
    Ray
    I hope you dance
    • John S.
      • July 29, 2009
      • 640
      Re: 1955 guys?
      ray, do you have a date code on either of the manifolds?
      • Ray G.
        • May 31, 1986
        • 1189
        Re: 1955 guys?
        Hello John;
        Check and get back to you.
        I hope you dance
        • Ray G.
          • May 31, 1986
          • 1189
          Re: 1955 guys?
          Hello John & Roy;
          No date code(s) I can find.
          The "indent" manifold reads "GM2" below the casting #. There is also a "2" on the inside facing the cylinder case.
          The non-indent manifold reads "GM1".
          These manifold have little corrosion. Possible casting dates were not cast on these manifolds?
          Will check for second design also.
          Ray
          I hope you dance
          • Roy B.
            • February 1, 1975
            • 7044
            Re: 1955 guys?
            Ray ! John and I are trying to get a consensus on them but again two 55 owner here? I see you don't list having a 55 ?
            I see restored 55's listed for sale now and then having many parts under the hood being wrong because so few people know anything about a 55 . The JM is a joke when talking 55. I don't think it will ever get done because there is little interest and so few 55's are left. Most everything is known about a 53 and 54 but a 55 . My thinking is that early 55 used the first pic. (no de-tent) but that's just a guess.
            PS: notice no response yet??? just YOU!
            • Robert J.
              • September 30, 2004
              • 117
              Re: 1955 guys?
              Hi Roy. My early 55 has the first type of heat riser xxxxx12 and the smooth casting on the manifold Bob
              • John F.
                • March 23, 2008
                • 2406
                Re: 1955 guys?
                Roy, Isent you pics of the manifolds on my stock 55 Bel Air on the other forum.
                John F
                • Roy B.
                  • February 1, 1975
                  • 7044
                  Re: 1955 guys?
                  I saw it and again thanks
                    Re: 1955 guys?
                    Colvin's "Corvette by the Numbers" book shows the 3704791 manifold with the depressed horizontal groove being pointed out in the photo as a Flint (Saginaw) casting, and the one without the groove (same casting number) as a Tonawanda casting.
                    That would preclude the one without the groove from being original to a Corvette engine, as Tonawanda didn't build Corvette engines.
                    • Roy B.
                      • February 1, 1975
                      • 7044
                      Re: 1955 guys?
                      So it seems to be the manifold having the grove is 55 Corvette ! We agree?
                      • John S.
                        • July 29, 2009
                        • 640
                        Re: 1955 guys?
                        john, roy has shown you two flint manifolds . the manifolds are ribbed and non ribbed . neither are date coded, but all tonawanda have date codes. in corvette by the numbers you will find a non ribbed tonawanda manifold date coded E 2 55. email me at scopeli@comcast.net and i will send a picture of a ribbed tonawanda manifold date coded E 25 55. i have other ribbed tonawanda manifolds, but i am trying show when a design change might have occurred. on the 55 corvette the generator ends up being very close to the exhaust manifold. the ribbed style allows more room. listed in the judging manual is also the second design #3837069. all of these appear to be ribbed from flint and tonawanda. ribbed tonawanda examples that i have examples of are date coded J 14 55 and K 21 55.
                        • John S.
                          • July 29, 2009
                          • 640
                          Re: 1955 guys?
                          robert, on the tombstone heat riser, first design part #3713331 with counterweight #3713335. replaced by second design part #3721509 with counterweight #3721512. (2nd design replaced 3713331 on july 1 1955). later the replacement is #3725981 (1956) square counterweight design.
                          • Cecil L.
                            • May 31, 1980
                            • 449
                            Re: 1955 guys?
                            Wouldn't it seem likely that the notch is for power steering pump clearance?
                            • Roy B.
                              • February 1, 1975
                              • 7044
                              Re: 1955 guys?
                              No! I Think is was to straighten that area and has nothing to do with PS or clearance for the generator
