still have carb problems - NCRS Discussion Boards
+ More Options
Posts
  • Tom K.
    • August 31, 1989
    • 28
    i followed the advice from my last post but i still have the flooding problem. how do i check the fuel line pressure as suggested?
  • Timothy B.
    • April 30, 1983
    • 5196
    Re: still have carb problems
    Tom,
    To answer your question get a vacuum/pressure guage and pipe it to the fuel line tight so no leaks. Start car and idle engine to check pressure which should read approx 5-6 1/2 lbs.
    If you removed the float bowl sight plugs and properly set the float level and the carburetor is dripping fuel there probably is a gasket sealing problem inside the carburetor.
    Be careful with your eyes looking over the carburetor..
